P38 Engine Removal
healey1006
Can the engine be removed without removing the transmission at the same time? The official Land Rover workshop manual I have only gives instructions for engine and trans removal as a unit.
it is easier to remove any engine when you do them both mainly due to all the nuts and bolts that are extremly hard to reach.
healey1006
Just to answer my own question for everyone elses information, it is not necessary to remove the engine and trans as a unit. I did it yesterday and it was not that big of a deal. Two of the bell housing bolts were a bit of a challenge, but otherwise pretty much the usual affair and since the trans. wasn't taken out along with the engine, there was enough clearance to avoid removing the coolers, condenser and grill. Today is the fun part, the new engine goes in!
jshand
Hi doing the same , engine out for rebuild, how was it to go back in? what did you do with the tork converter, mine came off with engine, cant see how to get at the 4 bolts with the sump on? any help wouild be welcome, thanks
