P0103 fault
pascaltissot
Hi Joey,I got fault P0103 mass Air flow Circuit-high input ,I changed the ERR2946 sensor I reset faults nothing did appear again ,but I wanted to know which fuse woks with this ?? So if possible to change it too...do you have other suggestions??or should I check any other part ..You’re the expert..P38 HSE 1998.
Saludos cordiales
Pascal
:hmpf:
Not an expert, just years of playing... no fuse that I know of, it gets its power from the ECU IIRC.
If the fault has gone away then all is good.
tflint2112
