over heating
M
mad gagsy
undefined CAN ANYONE HELP. OVERHEATING, BUT NO LOSS OF WATER. CHANGED WATER PUMP AND THERMOSTAT. RUNS FINE FOR A WHILE UNTIL COMES TO A HILL THEM TEMP. SHOOTS UP. HELP PLEASE THIS IS DOING MY HEAD IN. :mad:
D
discomike
What year and model are you talking about?
Did you bleeb the air out of the engine after you changed the coolant?
If you turn the heater on when it is hot do you get alot of heat or is it cool?
How many miles on the engine?
Mike J.
M
mad gagsy
yes i bleed the air out of engine
yes the heater is hot
the year is a 1991
MILAGE IS 106400 : :
THANKS GAGSY
D
discomike
You're down to 2 options, a plugged up radiator or a head gasket.
Mike J.
Sergei
Well it also can be thermostat with incorrect temp. settings. There are like 3 of general settings to my recollection.. Or can be bad coolant mixture :) Can be also fun clutch snuffing it.
But most likely its what Mike said - clogged radiator.
Disco2TrailEdit4
