oops
bear13
left the sunroof open, it rained, alarm activated would not turn off , disconnected the battery,reconnected the next day,serpentine belt started turning, horn was blasting (took fuse out)ignition key was not in ,wipers wouldnt turn off.any thoughts:confused:
You are in deep, wet trouble. Sounds like that dash got wet. I wouldn't leave the battery hooked up and pray that after a day or two of dry time, that it might be safe to hook up and try again.
What year of RR? but sadly I agree with Disco Mike (not sad about agreeing, sad about your issues).
I would leave the doors open and let it air out... and hope for the best.
wild rover
03 Range Rover HSE.
Hi all, from a first time poster.
Has anyone got an idea how I can fix this problem. I only got this vehicle last year after 20 odd years of dreaming, and last winter the battery died.
I replace it( following the manuals instructions); trouble is now one of the head light wipers is stuck in the upright position.
I didn’t mind too much but recently one of the kids left the lights on overnight and the dam thing was nearly totally flat and needed a jump start, which I did, again, following the manuals directions.
Later the information centre told me that the hill descent was not working and now the seat heater has ceased to function too, are these problems related and can I fix them.
All help gratefully received.
wild rover
03 Range Rover HSE Electrical trouble
:stupid:.
Wild River, sounds like you need to replace the battery again. Sounds like typical battery issues. Not the stuck wiper, but the new issues.
