Oil Change
Kmac
How often should I change the oil in my 2015 Range Rover Sport?
Depends on driving habits, I am sure the manual says every 15k, but if you drive a ton of stop and go or dusty areas, then I would say more often. If all highway, then you can go longer. Ultimately though it depends on how long you plan to keep it as well. If you plan to keep it well after the normal 3-4 years of vehicle ownership then I would change every 8-10k at least.
dj_karl
I know others are doing it every 7500 miles. Besides, oil is not too expensive.
