Thanks guys.
I'd like to use these as fog lights but understand that if the dealer activates them through the factory harness they will only work with the headlights on. Is there a way to get them to work without the headlights on?
Regarding the wiring, yes you can do just about anything (have them operate independently, have them turn on with the fog lights, etc). However a few things to consider:
1) Fog lights have a different beam pattern, the OEM driving lights would not really work well for this
2) The position of fog lights should be low to the ground. The OEM lights mount too high for this purpose
3) Laws in many states prohibit independent functioning aux lights and limit the number of concurrently illuminated lights up front, you may have issues with your state inspection
4) The OEM wiring harness is really only good for the purpose it was designed to perform. If you want to have an independent switch or have them activate with the fog switch, you will need to source a separate wiring hardess and DIY the wiring.
Hope this helps...
