need a screw for the oil dipstick bracket?
MetalMarine
If you are like me, and needed a screw for the oil dip stick bracket. Well look no further. I have found the solution.
I've found that the screws for the clips that hold the spark plug wires to the valve covers works pretty good. If you have a clip that isn't being used. You can take one of the screws out and use it to hold the dipstick in place.
Hope this helps, and this tip has probably been mentioned before...
:biggrin:
Welcome to the forum... nice first post... helpful.
MetalMarine
Thank you Joey. I check this place quite often but i usually use the other site a little more, since it was the first one i found a year ago when i bought my first disco. I hop around looking at different forums looking for things to do to my rover, and if i can help someone, i try to chime in. Ive been looking for that screw for some time now. and it finally dawned on me that i could use one from the clips.
thanks for the reply and thanks for all of the help you offer us disco noobs.
:biggrin:
