Meyle HD LCAs
The LR4 got it's third set of LCA's after the cheapies (eurospare? lasted 4 years and 35k kms) puked the oil and it was clunk clunk clunk. I was a little nervous of the solid bushing design vs the oil hydro bushing but ride quality does not seem worse. Let's see if they last but the arms looked to be quality. I would recommend at this point if you need to replace your LCAs. I got them through Lucky8.
Mozambique
toronto
Huh....... replaced mine with eurospares last year. Will see how they do. The previous OEM ones lasted around 60k km or so, so $ for $ the cheapies probably not bad value, especially as next time I change them no Sawzall will be required.......
Didn't use antiseize they just wore out quick and didn't have time to corrode ;)
