Just trying to find if anyone else has seen or heard of this issue as I’m unable to find what causes it, so far? Operating the lumbar adjustment pops the fuse on circuit 40. This is repeatable.
Its one of those faults that keeps on giving. Initially, I found the drivers window switch not working, put eventually found the cause to be the lumbar adjusting switch! Yes, drivers window switch, analog clock, and lumbar adjustment are all on the same 5amp circuit!
So far I have unbolted the seat, inspected the wiring generally, and taken the switch pack off the seat, dismantled and inspected that, and nothing obvious. Finding it hard to identify the lumbar pump and relay, must be hidden somewhere?
Anyone else seen this wacky fault?
Or know where the pump and relay are?
