Lucky 8 Prop Shaft grease zert size?
Thegreatpnw
Washington St
Hello fellow Disco owners, I need some help. I have a 04 D2 that I swapped out the old prop shaft with a new Lucky 8 version. I was greasing the ******* or zerts today and discovered that I was unable to connect the normal coupler onto the U-Joints ******. The ****** seemed to small and the coupler would not connect properly. The coupler fitted nicely on all the other ******* or zerts, so I was wondering since the Lucky 8 prop shaft is popular with D2 owners that maybe some has run into the same issue? I don’t know which size coupler to get if that is the issue… Thoughts would be helpful, thank you..
dimitricourmousis
