LR4 HSE coolant weird question
jackkyxu
2010 LR4 HSE
spent all the time in NE part, just temporarily moved to SE part
for the latest 3 months before reaching the SE, never had the coolant low message
this morning, I noticed the coolant low message, but ONLY once
I checked the coolant expansion tank when cold this afternoon, the tank is almost empty
the car just did a 600 miles trip, no message, no overheat, the water temperature seems in the right range all the way
any idea?
jackkyxu
It's not a recall. Technical Service Bulletins are normally. on your dime after the factory warranty is up.
sorry to ask another question
I read through the TSB, abut it seems there is no solution provided there
any one you can think of?
Thanks
jackkyxu
finished the 400 mile trip yesterday afternoon
the evening before yesterday, I put in 1 qt 50/50 mixed coolant into the tank to bring the coolant level up to about 0.5 inch above the upper range mark on the side the tank, then I used the car for a while,
parked overnight, yesterday morning before the trip, I checked the level, it is right on the upper range mark
I checked the coolant level this morning, the coolant level remains the same as staying on the upper range mark
will this help to pinpoint any issue?
Thanks
