LR4 drawer/slide setup - NY
mm3846
LI, NY
Custom built single drawer and fridge slide for a LR3/4. Will probably fit similar sized cargo areas… 4Runner, GX, etc. Is but at an angle to accommodate floor and provide level top. Plywood frame, solid wood drawers. Glued and pocket hole screwed, super solid. 200lb full extension lockout slides. Automotive grade carpet glued and stapled to top. About 100lbs or so, I can remove it myself. Attached with bolts on one side to factory tie down, and turnbuckles (included) on the other.Selling because it isn’t as convenient for me as I originally thought it would be. $400 obo. Located at the east end of Long Island, NY
Dimensions:
37 1/4” front to back
40 1/4” side to side
11 1/4” tall at the front
Slide will accommodate a 32x18 fridge/cooler
Drawer internal dimensions are 13 1/2” x 34 1/2” x 8
