lr2 transmission fluid
Ash khan
usa
Hi,
On my 2014 LR2 2.0L petrol L359, I noticed while driving the gear felt like slip, has approximately 86 K and I plan to change the transmission fluid. Any advise and link for the procedure and what type ATF fluid to use as the OEM is very expensive.
Thank you
Rover Range
Texas
The required fluid is Nippon AW-1.
Any compatible fluid will work. Toyota and Volvo also use this fluid.
You will need 7L
All you need to do is a drain and refill.
Remove the level and fill plugs.
Drain fluid.
Install the drain plug.
Fill fluid until it comes out the level plug.
Install level plug.
Add an additional 0.5 liters of transmission fluid.
Install fill plug
Fill plug.
Fluid Level plug
Drain plug
Ash khan
usa
Thank you. I am planning to change the transmission fluid. Are there any torque specs for tightening the drain plug, fill plug and re-fill plug or just tighten enough by hand. Regards
