Lower front caliper pins seized again...
You think I would learn as I went 18 months without re greasing the caliper pins in the front. Top pins were ok however the bottom pins won't come out. The bottom pins are the ones with the rubber grommet and I suspect the rubber may have swelled even though the grease is safe for rubber applications.
When I finally get the pins out I think I may try not running the rubber grommets.
