Low/High Range Switch Produces NO Chime or Message.
remember5
Can you hear anything happen when you make the change, does the indicator light on the console change from hi to lo? My shop manual is pretty blank on the section related to the transfer case, maybe someone else can post that section.
Abram Tunnicliff
Iron Mountain, MI
Nope. Sitting in the drivers seat, nothing mechanical is audible. Maybe I will crawl under and listen from there.
If it were possible that the problem is the switch, where would be a good place to get a replacement? Are there any highly recommended sites?
Disco2TrailEdit4
