Low beam replacement 2011 LR4
montyaloofah
So i got into my headlight assembly to replace my low beam bulb. Does anyone know how to unlock the bulb? The diagram on the manual does not match what i have on my headlight. It is stock. Am i missing something? i can post pics when i get home.
montyaloofah
Yup, figured it out. thanks. Just installed CrystalVision Ultra's for both driving and high beams.. very easy
jptruck
I assume there's no difference in the 2011 and 2012 model? Did you use the H7 or H11? I'm confused as to which to buy.
montyaloofah
i initially bought H7, but found that it could only fit the high beams. I then purchased the H11 and it fit the driving lights perfectly. the whole install was 10 minutes tops.
gvillalongo
