lift kits
Petep
Hi all, I have a 110 twin cab and am looking at a 2 inch lift. I have seen 2 inch spacers which mean |I can keep the springs and shocks I have. Are these any good and what do I need for the front? Cheers, Pete.
The spacers will work for front and rear. i had them on my 1997 D1. they work well, just remember shock travel will need to be extended
confirmer
Joey is correct, the spacer would work efficiently, but if you are aiming for a higher ground clearance, you will need to get an aftermarket lift kits.
Vintage99
