Just exceeded warranty, where is everyone buying oil and Filters from to perform fluid change
machmike
Pop your hood
Open Driver side door
Turn on acessorie (press start NO foot on brake)
Press and hold both the brake pedal and gas pedal to the floor for 10 seconds
This will reset the 'service required' indicator or reset the timer.
callin
Houston
So your level should be 1 notch below MAX on the digital dipstick correct with 8Q?
I read elsewhere on this forum it should be 8L not 8Q. Just want to make sure I have enough oil in when I change.
per the owners manual, the capacity is 8.0 liters or 8.45 quarts.
the amount of oil to raise the level from MIN to MAX on the display is only 1.5 liters (1.6 qt)
jlach993
Fresh Meadows Queens NY
Pop your hood
does not work for pre MY2013 Lr4's in case anyone tries
mmbirtcher
You buy a tool...or ignore it like I have for the past 10 years.
The GAP tool? I guess I haven't found that menu, lol.
For the OP - I use Mobil 1 Extended Performance, OEM filter and change every 7500 as per FSM. I have no idea why LRNA recommended 15k when their own FSM says 7500 :oops:. dumb
f1racer328
AZ
For a 2011 try Mobil1 EP High Mileage. Your LR4 is in it's Carlsberg years.
Don't high mileage oils contain additives to slightly swell seals to prevent smaller leaks?
I've been under the assumption that you shouldn't switch to high mileage oil unless your vehicles showing a reason to, and once you switch you shouldn't switch back.
dimitricourmousis
