Thanks a lot! Can you give me a bit more info on the two notes above? What holes don't line up, and what part of the exhaust do some grind off, the pipe is only so thick so I can't imagine making that thinner would buy more than a couple MM of space...
The distance between my front bolts and my center bolt was just a bit short and didn't quite reach so I had to make the holes a little oblong on the front ones to work.
The clearance between the plate and the exaust pipe where the big rubber damper is, it is very small and some have reported that it would vibrate on the plate right where the rubber part is mounted to the exaust pipe. I had this and the choices are to add spacers/washers to the plate to give it more clearance.
In my case I felt that the washers decreased the strength of the plate so I elected to grind the part where the rubber damper is mounted down some to get the clearance.
Sorry I don't have a pic but you can't miss it. You can feel how close it is by feeling up in one of the service cutouts toward the passenger side. At low RPM especially after things were well warmed up the vibration would be enough to cause a rattle.
