On a 95 D1 I was planning on also changing the single spray pattern injectors to 4 hole spray pattern injectors. Already did this swap to a 87 325is BMW of 2.5 litre and it idles smoother plus increased performance and fuel mileage with cleaner smog test readings.
I know the 3.9, 4.0 (stupid as same bore & ****** fooled the public) plus the 4.6 litre all use the same size in pounds per hour injectors. I have not a clue what they are in Rovers. All my manuals are in storage and not handy at the moment. At Pick N Pull the Ford 302 ** engines have 4 hole 19# injectors. With a collecton of extras for two engines I can flush and flow check for a balanced spray volume set as well a spray pattern.
