Hot Start Problems
greg409
Your idle air controller (IAC) i believe is mounted on the rear driver's side of your intake plenum box (top).
Mine is on the throttle body, but mine's a '97
If you do a search, search "cleaning IAC" or "cleaning stepper motor(same thing)"
read about it, even if your reading about a different type, the solutions are identical.
Do not push/pull the stem, as you will change the reference point that your ECU has developed over time.
Finally, the idle jumps in park/neutral as you've removed the driveline load from the engine, but the IAC can't drive closed due to carbon buildup.
I used a toothbrush & wd40 to clean mine, don't forget to clean the hole that you pull it out of.
After it's cleaned, repost for more suggestions.
luck,greg
wolf
Only thing I would add is that there is better sensor cleaning sprays out there than WD40 - and for crud-busting as well; take a look at NAPA - Sea Foam comes in a spay can ideal for cleaning situations.
Wolf
