Hood Open Warning
djatkinson
Hi, all,
My '06 LR3 has the Hood Open warning, but the hood is apparently properly secured in place. It seems that I remember a certain indicator or sensor that need to be replaced. Does anyone have any info on the part number and procedure for replacing it?
Thanks in advance!
Dan
ernest jarvis
Huntsville, Tx
Also, don't set your alarm - its tied to the same sensor and will go off. There is a sensor in the left front hood latch (there might be one on both latches, the latch will have a wire connection). You can try adjusting the latch or just replace the whole unit - easy to find on ebay, etc. There are some good videos on you-tube.
Good luck.
Van
ernest jarvis
Huntsville, Tx
Forgot to add . . . Its usually the front left latch that's the culprit per my Land Rover specialist. Just do a google search for LR3 hood latch and sources will come right up. Same with you-tube search for LR3 hood latch replacement.
remember5
Here you go.
  • Hood Switch Removal.pdf
grimmecm
Had this same issue. Left latch (passenger side) was it. Potentially the easiest fix i've ever done on the lr3.
dimitricourmousis
