Headlights LR4
obdoc
Lots of forums on headlight replacements, but many are outdated. I need to replace my 2012 LR4 low beams. Want good look, but good visibility is more important. So which bulb--Philips Crystal Vision Ultra, Philips X-treme vision, Sylvania Silver Star Ultra or Sylvania SilverStar zXe?
eljefe
do you have HID D3s bulbs? my 2010 one of the low beam d3s bulbs is dim. I am looking for replacements at the moment. These d3s bulbs are crazy expensive. not sure if I should change both at the same time.
LR4PDX
Stay away from Sylvania Silverstar Ultras. I burned through 2 sets of those in less then a year. I now use them for my high beams and fogs, not low beams.
Very good, bright light, but burn out in months.
billj214
I tried lots of bulbs trying to achieve a slightly whiter look to match the LED's, this is the best option I found. These are H9 but fit H11 with a quick trim of connector tab. Blue tint but higher wattage so no loss of light, also great warranty. PERDE H9-65-BX2 Solar Series Platinum Halogen Bulb, Set of 2 https://www.amazon.com/dp/B00B85PWYA/ref=cm_sw_r_cp_apa_Tkv8xb99GMG5W
Sent from my XT1254 using Tapatalk
Surfrider77
I bought a set of LED fog lights through the @carid website. While the color was a nice white, the actual output of light was total ****. The stock bulbs put out far more. I basically threw them in the trash and purchased Phillips Diamonds from Amazon.
Putting LED lights in a housing designed for a halogen bulb is a very bad idea.
billj214
Yes LED's light output is not focused and blinds oncoming drivers, I highly suggest H9 bulbs with 65 watts output and blue tint. You'll get the whiter look and higher output compared to tinted H11. Does not change the factory light pattern.
Sent from my SHIELD Tablet K1 using Tapatalk
Oledave49
