try charging up the battery
tlt's comments are much more helpful than mine below.
Just to eliminate a number of possibilities, if you can, put your battery on a battery charger for a few hours, but more importantly, each night, put the battery on a trickle charger for a week or so.
You may have a problem with the electrical charging system.
There is an alternator failure mode that is really the regulator has failed or is failing and it goes into a sort of fail safe mode where it keeps the charging voltage to about 13 volts maximum. That is not enough to fully charge the battery. The alternator will still make enough power to run the headlights and engine, radio etc, but not enough to really charge the battery as strictly speaking, it is a regulator problem, not an alternator problem.
As such, the computers detect under voltage and tend to sense problems that are not really there.
The fact the four way flashers go on for no reason is a symptom of the 3 feeling sick. The flashers will go on if the computers think the 3 has just been in an accident - that sort of thing; hence getting the battery fully charged and keeping it that way for a week of so of normal driving around could be helpful.
It could be that the problems will tend to disappear. If so, when you stop the charging, then the problems might reappear; if so, then maybe you have a problem with the charging system - either the battery or the alternator.
