GPS and TPMS woes
ycharlie
Hi all, recently I've changed out my TPMS sensors trying to make the alert on dash disappear. After putting in new sensors the tech the car is having a tough time syncing with them. Tech confirms the sensors are good but the car does not calibrate even after a long drive. After trying a few things I've noticed the car's GPS has a strike through it. I read somewhere that the TPMS will require GPS to sync or vice versa. From my search, it seems I can either do a hard reset of the car by disconnecting the battery or eventually replace the actual antenna. Does anyone have any input on this?
Much thanks in advance!
Make sure you used the right Mhz TPMS for your vehicle. Land Rover did a switch in 2013.
