Gas cap fault
drzjoint
I am getting a loose missing gas cap display. the cap is tight I have taken it off and tightened it down a few times. any one else get this/ what fixed it. thinking the seal on cap dirty???
squarecircle
Greetings drzjoint; It is a common problem. Try this for a quick fix.
1. Remove gas cap.
2. Wash and clean in soapy water.
3. Dry cap completely (hair dryer or other Hi-tec tool).
4. Clean gas filler inlet with damp rag.
5. Dry gas filler inlet with clean dry rag.
6. Spray both cap and filler inlet pipe liberally with a silicone lubicant.
7. Reinstall gas cap.
Worked for me!!!!!! >>>>>>>>>>> Regards,sq.
Roverine
Can also be a faulty sensor in the fuel system. That was my problem.
