Fuse box
Donjames911
Anyone know how to pull the driver's side fuse box on a '97 Disco? I have a loose hot wire (cigar lighter) behind the fuses. I can see some plastic clips on the RH side of the box, but can't figure out how to use them w/o risking breakage. Thanks in advance for any suggestions. :argh:
Never tried to remove mine.... I will look at it in the morning and let you know how it comes out.
Donjames911
Joey, n/m on the fuse box, found the 2 bolts holding it. Can prolly get them out, but it will be a real PITA getting them back in. Will be easier when I figure out how to pull the wiring plugs on the front to get them out of the way-those little plug latches are a bear in that confined space.
Has to be done tho, can't ride around with a loose hot wire behind the panel.
Life's a Disco, and then you die, LOL :biggrin:
