Fuel Trims - Can it be adjusted with GAP??
samnt650
2007 V8, 166k Miles. Cats O2 MAF Replaced at 100k. Plugs, Radiator, thermostat, water pump, EGR replaced at 150k. Dual batteries. Original Brake Switch. Have P0420 & P0430 codes (they have been around on and off since 70k miles)
I have noticed my Bank 1 Long Term fuel trim is 1.5 to 4% higher than Bank 2, both under load and idle. Short term fuel trims on both side seems to be ok. Lambda reading on both sides are fairly equal.
QUESTIONS >> how should I go about troubleshooting why the imbalance? Full computer reset dont fix the problem. I do have the latest LR firmware on the truck.
Running out of ideas how to solve this...
