Front tow recovery hooks?
Forty Deuce
Ok, as a Land Rover rookie here allow me to ask a question. I see a posted picture of a tow hitch recovery attachment. It also appears this would mount directly below the tow hitch receiver at the rear of the vehicle.
First, am I correct? Second, based on on training I received for the recovery procedures & use of a Cayman MRAP (admittedly, clearly a VERY different beast in both weight, construction, and use than a Land Rover) we were strongly cautioned to only use hard recovery points and never the tow hitches. We were explained that tow hitches were designed for direct pull/force in a single direction and not recovery points which exert different forces in a different manner. Are tow hitch recovery accessories common use in Land Rovers?
I ask because I had a small degree of comfort with recovery operations based on this training but am I a victim of my own ignorance? Admittedly my training was vehicle specific and therefore it may be absolutely worthless outside that realm and/or simply stated as a risk reduction measure.
I intended to attend a Land Rover Experience class as well as join a local Land Rover club before I went on any off road excursions of my own. I'd prefer to learn from experienced operators and instructors than just "trial & error" my way through learning.
The big recovery ring on the bumper is meant for recovery... a hitch mounted one would reduce clearance due to the hitch and be less strong I would think...
Daniel Hull
The easy answer is that you have much better recovery point right above the hitch, so there is no reason to use the hitch. That's an LR4-centric answer.
In general, a tow hitch could be used as a static recovery point (e.g. pulling with a winch) but I wouldn't use it for a dynamic (****** strap) point. As you say, they are designed and rated for static loads. I've seen plenty of instructors show how to use one as a recovery point though. Similarly, if you are planning to pull someone out using a ****** strap, attach it to your recovery point, not your trailer hitch.
Forty Deuce, you are correct in all your assumptions. The photo of that hitch recovery attachment was posted by a member unfamiliar with the LR4's built-in recovery points, and based on his experience with Disco 1 and Disco 2, which are very different animals.. For several reasons listed here, a hitch receiver is NOT a recommended recovery point for the LR4, but the factory points hidden under removable covers on both front and rear bumpers are, along with some suitable D-shackles and ****** straps.
Railey
Yeah it was me. I was going by the OP which asked about locations to bolt on aftermarket hooks/rings, so I posted a couple photos of them. I am used to lifted D1 and D2's. Apologies.
Sent
Yup, 3/4" is what I use, with plenty of room to spare. I guess you could use a 1" shackle if you wanted too... Not that you'd need it, but you could.
Secated
Cool, thanks. I guess I should have bought the one I had in my hand today:).
Surfrider77
Literally the same exact D shackle I use. I recover (other vehicles) probably more than anyone else in this LR4 forum. Living in the middle east, its sand recovery every other outing.
I always carry 2x:
Amazon.com: Smittybilt 13047B 3/4" Black D-Ring: Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/41EePDG6T4L.@@AMEPARAM@@41EePDG6T4L
And 1x:
Amazon.com: ARB ARB705US 2-3/8" x 30' Recovery Strap - 17500 lbs Capacity: Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/31O0BElwMOL.@@AMEPARAM@@31O0BElwMOL
I have imported quite a few sets of these for other friends with Jeeps, etc.
If I had a roof rack, I would probably buy a pair of Max Trax to make things even simpler.
https://maxtrax.com.au/
