Front end lower than backend
chrisp
I recently noticed that the front end of my LR4 is lower than the rear. I measured and it looks like it's about an inch lower in the front. Is this normal? I'm on brand new tires all of the same size.
Maybe the air suspension in the front needs calibration?
Thanks!
1" or so sounds about right. The standard measurements for the LR4 - from lower wheel arch to center of the wheel (this is from my IIDTool manual, and it's the numbers you use as a baseline when re-calibrating suspensions height) should be 466 mm front and 485 mm rear, which translates to about 3/4" difference between front and back. Lots of things can affect those measurements however: how long the car has been parked and level, how much crap you have in it... But it doesn't sound like yours is in need of a calibration quite yet, definitely not for a negligible +/- 1/4" difference.
