Front cigarette lighter not working
RR#23
Hi! I have a 2006 RR sport, I tried replacing it and check all the connectors and fuse but it still does t work. When I took out the center console I saw some sort of soda spill. The light on the lighter/ashtray works sometimes but the lighter doesn't. Please help. Thanks in advance.
When you replaced it, did it have power to the plug?
RR#23
No power, I wanted to cut the connector and just tap it straight to the wires.
If it doesn't have power then you still have a fuse issue somewhere.
I sadly don't have the schematics on the new RR, but I will contact a friend and see if he knows.
Fuses are behind the glove box... check there first... Not sure of the fuse number, but I am sure one of them will be bad.
RR#23
I checked the fuse for the lighter and it was fine, I'll check the other ones
