freelander light-on
M
meky
In my freelander dated 1999, the orange pilot lamps "TC", "ABS" and "HDC" are every time light-on.
My car mechanic have changed the brake oil and the pilot lamps are light- off,
but only for little time: after 5 day, the pilot lamps are again light-on.
Can you help me to solve this problem? thank you - Meky.
R
rintin
I had a similiar problem on mine and it ws caused by a faulty brake light switch!! Worth a try changing it as it isn't too expensive.
R
RoostasTowel
Got a similar problem on mine,
The TC and HDC (amber) lights come on simultaneously when brakes applied. They stay on for about 5 seconds then extinguish.
When the car is stationary, the lights come on only when the brake pedal is applied.
Brake light switch sounds like a good fix. Hope so, cheers.
R
raznamo
Same thing's happened to my '04 Hippo and LR replaced the air flow sensor. Hasn't happened since then (6 months ago).
Good luck!
R
RoostasTowel
Switch did the trick. Chap at the LR dealer said they had modified the switch as the old design was faulty. It was only when I got home that I realised I should have asked for a free switch.
dimitricourmousis
