USAFbuckeye
- Joined
- Dec 8, 2008
- Posts
- 280
- Reaction score
- 1
Was wondering if there was a way to fix a leak I found on my compressor. I kept getting a "Suspension Fault Normal Height Only" message. I could hear the compressor working then cut off and then the fault message would appear. I decided to take the cover off around the compressor, start the truck and see if I could find what was wrong. Sure enough I started to hear air "hiss" from the bottom line that has a blue grommet around it. It's leaking air from where the line goes into the compressor. Not sure if the line is cracked, but it's not hard nor brittle. Is there a way to fix this myself?
I do have the ESP warranty, but I'd like to fix this myself if it can be done.
