Flashing Parking Brake light on dash
Benner
Hey guys,
So starting last night I noticed that when I started up the LR4 the ebrake (which was on) started flashing. It happened the same time as both of my headlight bulbs burnt out. I just replaced the headlights today but I'm not sure if it's related in any way. Has anyone had something similar?
For reference: 2010 LR4, 135,000 KM
Just did the brakes about 2 weeks ago as well.
pic for clicks!
kdegLR4
I'm going to speculate that, unfortunately, it is likely the parking brake actuator.
Ours failed over the summer with the brake locked on. Other symptom was a loud squealing from the rear brakes, like the sound of a rock in the caliper but on steroids. Cost a bit under $1k out of warranty.
If your P brake is off, leave it off! If it's on and you hear the squeal, immediately shut down, pull up the center console/cup-holder and manually pull the brake release cable (it takes a surprising amount of force to release, keep pulling, it won't break).
best of luck, hopefully yours isn't the actuator!
AxelR
I had the same issue as you and had to replace the parking brake actuator kdegLR4 on my 2010. Fortunately it was under warranty.
  • joey
