Final Warranty Check - Suggestions?
Stealther
I'm approaching the 50k cutoff of the Factory warranty on my 2013. I will still have the CPO warranty till 2019/100k but I was curious if there was anything not covered under the CPO warranty that I should have them check at the Service Center before the threshold was crossed?
Any suggestions on where to direct them to inspect in particular? I just ordered a GAP Tool on the Black Friday special so I plan to check for potentials there as well. TIA!
Surfrider77
Front lower control arm bushings. Seems to be the highest failure item on these trucks. Very well could be classed as a "wear and tear" item though. Worth asking anyway!
PaulLR3
Boston
Agree with Surfrider77, have them check the suspension. Just had mine in at 48K miles. Lower control arm bushings were fine but they did replace the worn sway bar bushings for free under warranty.
If your coolant level is low, have them check the water pump for a slow leak. Both of our LR4's have had the water pump replaced.
Also, I had them check the battery. It was very weak but not weak enough to fail, so I had to pay for a new one.
Stealther
Thanks guys, I'll have them take a look at all the bushings and the water pump.
