Engine light + "Restricted Performance" warning in cold temperatures
hatch
Pennsylvania
I believe I had this happen once last year on a particularly cold morning. This year, I've had it twice now. Once when it dipped into the 20s overnight, but again today when it only got down to just below freezing over night.
I don't notice any change in the way the truck drives, and in every instance the light and warning message have gone away after 3 engine cycles.
Ignore it? Or worth checking out?
scott schmerge
Charlotte, NC
The codes? If it’s p2118-19 it’s Likely a dirty throttle body. Do a really good job of cleaning (it doesn’t take much to make that code trip). I also got a code for the MAP sensor (sits right behind the throttle body).
my money it’s this
hatch
Pennsylvania
my money it’s this
Unfortunately, I don't have a GAP tool to provide more info. Wondering whether this is worth going into the dealership for.
scott schmerge
Charlotte, NC
go to autozone and pull codes. Free
You can even go ahead and clean your throttle body without pulling codes. My guess is it’s got some carbon buildup. If it stops going into restricted performance, that’s your cause. Make sure to get around the pivots on the butterfly
hatch
Pennsylvania
Had no idea you could pull codes at AutoZone for free. Will have to check that out.
And the carbon buildup would make sense re: it tripping the code/warning when temps drop?
scott schmerge
Charlotte, NC
Yes, that would make sense. Air is more dense when it’s cold, and your throttle body is slightly smaller in cold temps. Even the slightest variation with a little carbon buildup could cause.
bbyer
Alberta
Just a comment from up where cold is a norm. The heater in my 3 is good for about -35F on the highway as is the rest of the vehicle. Even by Made in USA pickup standards, that is good and it starts etc.
While a dirty MAP is probably the problem, check how the piping between the air filter, the MAP and into the engine is connected.
I discovered that the dealer service guys were checking the air filter by just undoing the air filter lid screws and then tipping the lid up to peak inside.
This was effective, but what also happened was the piping downstream of the air filter that was torqued upwards, tended to open up at those rubber seal joints and hence leak air. Effectively, non filtered air was entering the engine downstream of the MAP and that messed up the air metering.
For me, there were no lights, but the hint was that the fuel mileage went bad by about two to three miles per gallon.
