ecu adapter
97rover
1997 Range Rover HSE. Does anyone know where to hook up the computer scanner on this one. Trying to scan my Rover can't find where to hook up the computer. Any help would be great.
On the RR it should be just above the gas pedal under the lip of the dash. IIRC.
97rover
well I was checking the CD and it said it was under ther driver seat. Plus there is also another hook up for the BECU under the passager side foot panel. On my 97 Disco it is right above the gas peddle. I will look in both places and post my findings. Thanks for the info
healey1006
If you're referring to the OBD port, it is on the passenger side, upper left.
97rover
thank you but already found it after trying a dozen other places. Why couldn't they put it in the same place as all there other vehicals?
