Dup - ignore - Sqeaky passenger rear wheel after disc and rotor change
5crows
Lake Wisconsin, Wisconsin USA
2006 LR3 HSE - me and neighbors recently started hearing an annoying sqeak/squeel from passenger side rear wheel. These were new discs and rotors from Atlantic British put on about a month ago.. First pulled out wear checker, thinking it was cause - not.
Touch the brake petal and it would stop. Also recognized it started when making righthand turns. Not driving straight or making left turns.
Took off tire and checked disc wear and placement, all looked fine. Also removed rotor and checked/adjusted parking brake shoes, sprayed everything with brake cleaner. Noise gone for a day or so, then started up again.
Any idea what the noise is coming from other than brakes? Is this a caliper problem? Bad disc quality?
Any suggestions would be appreciated, annoying problem persists.
dimitricourmousis
