Driveline Noise *clunk
samnt650
MY o7 LR3 is having some kind of clunk noise, when I brake hard then accelerate hard. The noise feel like coming under the center of the truck. Is this truck had any known issue with transmission / transfer case /diff mounts? Its difficult to see what moves at the undercarriage.
My truck is wheeled regularly (aka, use as intended...)
To rule out, the noise are NOT from any of the control arms. They are replaced.
Globetrotter
Australia
There is a centre support bearing for the drive shaft that is known to wear and cause noises.
Alternating don't brake and accelerate hard till you find the fault:(
samnt650
Not like I dont have enough repair line up for Xmas already. Line this up as another to-do item... I am not getting any drive line vibration but just a clunk. Let hope this wknd I dont have to pull / tow someone out of trouble (yes another off-roading event..)
06L319
Minneapolis
Have you checked your rear drive shaft carrier bearing? My 06 had a clunk/feedback in the drive line and the rubber bushing around the carrier bearing was 80% torn.
...anyone know if a new driveline, when purchased, comes with a replacement carrier bearing?
06L319
Minneapolis
I believe it does indeed come with the carrier bearing installed. There is a good YouTube video on how to replace the bearing yourself if your so inclined. I however decided just to buy a good condition used LR3/LR4 shaft and the swap was MUCH faster. :) I now have a back up shaft just in case I break one wheeling.
Same here...I was having a new motor installed on the (locking) rear diff, they had to take the shaft down anyway so I had a new one put in. I was only asking to give myself peace-of-mind that the bearing was refreshed as well.
