Drive Shaft
hkd60
I have a 2002 Discovery II front drive came out can I drive without it in??
Thanks
greg409
Did it break or did you remove it?
If it broke, have you inspected the transmission housing - looking for signs of impact, cracks, holes, etc.
Generally what happens when front breaks.
If none, and you have a working center diff lock, lock it and drive. (at least until you can repair the shaft.)
Absence of front shaft will increase the load on the rear, so drive nice.
luck,greg
The 2002 doesn't have a Locking Center Diff, so unless you have changed the transfer case you can't drive without the front drive shaft.
  • joey
