Crazy suspension!
Canalawyer
Hi guys, lately my LR3 2006 suspension is going crazy, for example when doing a stop light it levels up in the front, other times down, same happens in the rear... time to time indicates suspension fault (yellow warning)... but goes away by itself!!
Any advice on this one or somebody with the same issue??
Again thank you for your help!
BearishDriver
sorry mate I've had kinda the same issue for months now! apparently it is either a faulty valve or a leaking compressor but tbh I (my dealer) am (is) not sure so I decided to run like this until my compressor burns out. Please update if you find a different solution
tlt
Might be related to air bag leaks, or bad front or rear valves... Does it leak down at night? What about putting it on 4x4 Nav screen does one wheel go crazy (bad height sensor).
