Cosmetic for sun damage?
Lgibson
So, 8 years of desert sun have taken a toll on our Corris Grey LR. I know the correct fix is a new paint job. In the meantime is there something I could apply to make it look better?
f1racer328
AZ
Could do a wrap, but they're not exactly cheap. Cheaper than paint though.
Is your clearcoat failing/flaking off?
powershift
Nevada
It depends on the damage, but it might look slightly less bad if you polish it and if you use good polish it has UV protection in it so conceptually it may not get worse. Did you wash it and polish it on a regular basis? My last car has UV damage from the sun and I polished it 0 times in 12 years. I also didn't wash it religiously. With my LR4 I've had it about a month and polished it 3 times so far. I've got 2 more coats I'm going to do before calling it good and then in 3 months I'll polish it again.
Longtrail
Ann Arbor
What are peoples thoughts in terms of a good polish? I tend to use Autoglym super resin polish, it's a lightweight polish:
Curious to learn about other good ones, like powershift I'm in the process of polishing my LR4 regularly to spiff it up.
Lgibson
The clear shows no sign of flaking. It just seems to be vaporizing, probably by heat. We see that very often in the desert. It is epidemic on darker colored Chrysler Corp vans with the angled hood. Not so terrible on flat surfaces like the LR hood.
No, it was washed regularly but never waxed. My SO's daily driver.
powershift
Nevada
I have used Zainobros polish since the dotcom boom. It is kind of complicated and requires a lot of effort, but it shines nicely and their products have evolved over the years. On my LR4 I used 1 coat of Z-AIO to clean and lay a base coat, then 2 coats of Z-5 to hide some swirls and next I'm doing Z-2. Their towels are amazing, the yellow/tan ones are for Z-8 the white towels are for removing polish.
txfromwi
My regime for the exterior.
Painty Bits:
Wash it
Clay it
Touch up paint as required - I'm a hack at this part...
Klasse (German made liquid wax) - 3 coats
Carnuba Wax (spray on) - 2 coats (takes out any swirls and is crazy shiny)
Graphene - 1 coat - 303 Brand
Carnuba - another 2 coats
Light Up Bits
Wax the front, rear and fog lights with a soft paste wax - 5 coats
Wax the lights again - Graphene - 1 coat
Plasticy Bits, Window "seals", Door, hood and rear "gaskets"
303 Aerospace UV protectant
(Do this before cleaning the glass - you can clean off overspray at that step)
Wheely bits
Gel wax on the rims - 1 coat
Tire Black
Glassy Bits
Krystal Vision Glass Cleaner - amazing stuff - trust me
Disco2014
Hamburg/ Germany
I spraypaint with rubbercoating and i´m very happy with that.
If needed i just doing the ugly spots again. And thats it
powershift
Nevada
I applied some Zaino Z-16 to all the exterior plastic because it has UV protection and I live in a high radiation area. There is a surprising amount of exterior plastic on the LR4 including the windsheild nozzles on the hood, headlight nozzles, ground effect panels, mirrors, the cowel thing under the wipers, bumpers and Z-16 is also a tire dressing so I did the tires too. The aspect aside from UV protection that I like is a newness effect where it darkens the material slightly without a greasy look. Its a silicon based chemical. Overall the LR4 looks good on the outside for 98k miles and 11 years old. Pictures don't do it justice.
