Coolant Temps - 5.0
M32H32IS
Texas
2012 LR4 US Spec 5.0
I noticed coolant temps are running 5-10 degrees more than normal if I sit for a couple of minutes in Drive (stoplights) blasting the AC.
Driving temps stay the same.
Temps only rise when stopped and in Drive w AC on. If I put it in park and rev over 1,000 rpm the temps go down.
If I run with the AC off, the temps don’t rise above normal.
Nechaken
Colorado
Makes sense, especially in TX -- the 5.0 (and 3.0 for that matter) utilize an egnine-driven viscous fan rather than a separate electric one. If you shift into P or N when its hot you'll see the car up the idle speed to ~1050 or so RPM to speed up the cooling fan. But nothing it can do when you're in D and idling at 650 (or whatever). You'll probably notice the A/C isn't quite as cool when stopped, either.
M32H32IS
Texas
Can confirm that the coolant temp stays 91c and below during my morning commute. Same commute. Same stoplights. I guess it loses some efficiency in the extreme heat.
This morning it’s only 88f and functioning normally with AC on blast.
AC temp is also cooler
Tapps33
Bath, Maine
It could also be your viscous fan is getting a little weak. If the fan's viscous clutch is slipping more than it's supposed to, you'll never get the cooling factor for both the engine and the AC. Hence the temps will be a little high at idle, and the AC won't be as cold. Once you start moving and get a little more air and engine rpms, everything's good to go.
That said, I have never tried to see commanded vs actual fan rpms via the Gap tool...but I have to assume it's possible.
djkaosone
'11 LR4 HSE LUX 5.0L V8
SoCal
I wouldn't be worried about it. In high temps in Death Valley, CA around +115*F, I typically see coolant temp on my Gap IID Tool around 210-215*F at the engine and 185-200*F before the thermostat while blasting the AC.
f1racer328
AZ
230 is kinda hot on the coolant. That’s about where the car decides to shut off the AC and the gauge cluster coolant indicator will move.
It’s not going to boil at 230 if it’s holding pressure. I forget what PSI our cars run at, I think it’s about 25-30 PSI. So around 280-300 degrees F.
You should be running anywhere from 190 - 210. I run around 200-210 degrees when towing a 4500 lb trailer in 110-115 degree weather. (V8)
f1racer328
AZ
GAP IID tool.
Any OBD reader should be able to get coolant temp off our vehicles.
powershift
Nevada
That is impressive cooling capacity. I'll be driving around in 120F ambient with just the AC on and overland gear so if I hit 230 then it is time to pull over. My blue 2012 HSE LUX ships Monday. Hopefully on Saturday I can take it out into the desert and climb some mountains. It will be hot asf.
