Coolant Crossover Pipe Repair 5.0 V8
f1racer328
AZ
UPDATE: I am still leaking coolant from somewhere... I just haven't figured out the source. It's strange because it is inconsistent and there are no signs of leaking or dripping from the engine... block valley is dry, front of engine is dry, back of engine is dry, hoses and connections are dry... yet, there is coolant on the skid plate (towards the front) and in the driveway. A possible correlation I am starting to see is that it only seems to leak when it sits overnight, and the outdoor air temp is fairly cold.. below 40ish degrees F. So far, it hasn't dipped below that temp very often, which kind of makes the inconsistency make sense. I am wondering if there is a hairline crack in the radiator that only leaks when it contracts from cold weather... previous pressure tests didn't indicate a leak there, but I guess I will try again. My knowledge is limited, so will be grateful for any help with a few (probably dumb) questions:
-I haven't pulled the skid plate off yet to see drip locations, but what coolant components are towards the bottom of the engine bay that I should consider?
-Will a cold engine cooling system pressure test from the reservoir show a radiator leak? My simple understanding is that the thermostat blocks flow to the radiator until it warms up.
-Is there a way to pressurize only the radiator using the top hose? (This may be a dumb idea)
-Maybe a dye test would be better?
If you have OEM coolant (and maybe other brands too, not sure) it will glow pretty good under a UV flashlight.
I had a very small leak from my radiator. Coolant never even hit the ground.
txfromwi
As above, OEM coolant is UV active, no need for adding anything.
Plenty of locations to examine, take your pick.
Time to get dirty!
RoverTide
Memphis, TN
Thanks guys... Will grab a UV light and take a look.
F1racer - did you end up replacing your radiator?
txfromwi - Thanks for the cooling system images. Curious where you got those?
f1racer328
AZ
Yup. It was a pain in the ass.
It's difficult to remove if you don't disconnect the AC condenser and evacuate all of the refrigerant.
It was easier getting my replacement in, but that was after I figured out how it was going to fit. I think there are a few threads here related to the replacement.
RoverTide
Memphis, TN
Good to know. I need a new ac compressor... So, if my radiator needs replacing I'll do it before I fix the ac.
Jimmy Brooks
Pasadena California
RoverTide
Memphis, TN
Latest.... Had a few puddles under the car, and had to add a few ounces of coolant earlier last week. So, I added some UV dye to the coolant and have been driving it for a few days. I haven't seen a puddle under the car, nor have I seen any glowing drips/leaks (using the UV light) anywhere in the engine bay since. Not sure what to think about that. I guess I will just continue keep an eye on it.
