condensation in rear lights
Flyingscotsman1
hi all anyone ever come over condensation in the rear light plastic cover as i an having problems with my 2008 vouge
CaptainPanic
Yup, either the groomers have jet washed it or you have been thru a car wash which has forced some water through a gap in the silicone seal between the lens and the body of the light unit. You need to pull the light unit off and VERY GENTLY check all round the join. There will be a gap which you will need to seal with silicone. The best repair is to CAREFULLY and GENTLY remove the lens entirely, clean off the old sealant, dry out the unit completely, renew the silicone sealant and reassemble.
Easy peasy !!
