Cheap Way to Replace New Style 02's
I found out today that you can in fact use the less expensive older 02's on the late model D1 with the Advanced Evap. system. Turns out they both use the same 02 body, the only difference is the plug, which if you are very careful, you can remove the old plug, don't cut the wires, use a minature screw driver, and install it on the less expensive 02's and you are set.
To verify this, look at the model number on both 02 bodies, they are both the same.
antichrist
D1 w/AEL o2 sensor, NTK 25044 - $53 from Amazon.
I haven't seen DII sensors for less than that.
jastutte
any idea where to find the best price on D1 w/o AEL O2 sensors?
jastutte
yeah. sorry. that occurred to me right after i hit the send button. nothing like wasted bandwidth.
tflint2112
