Changing Starter Motor on LR4
Jasevo3rs
Houston, TX
Had a look around the web and cannot locate anything specific to changing the starter motor on a 2012 LR4 (5.0). Found a few youtube clips on Range Rovers and LR3's but not the LR4.
Anyone done this themselves and if so, any tips?
Cheers
DUNCWALT
Texas
Piece of cake, right side, take off wheel and then two plastic splash covers, solenoid wire, starter wire and three bolts. Takes abouts an hours to an hour and a half max to take out and then the same to put back together. Watch out for different nut configurations though and check the stupid starter fuse. For some ignorant reason, the solenoid is not fed off the same circuit. So one can think their starter is bad due to a solenoid click only. But the 400 AMP, nuclear detonator fuse might be blown.
Good luck
dimitricourmousis
