Camera/parking sensor issue
James Weinberg
Ypsilanti, Mi
So I recently got a 2010 Range Rover HSE supercharged. I get an error saying camera system fault, running the self test it shows error “rear/prox video input failure”. I also am having an issue with parking sensors, not working at all. Button in the cabin also does not light up or activate system when pressed. I looked at the fuses but didn’t find any issues. I feel these two issues are related but having a hard time trying to troubleshoot.
James Weinberg
Ypsilanti, Mi
That was the first thing I checked, all seemed good though I can check with a multimeter when I get home tomorrow. I also switched the relay thinking that might be contributing, but didn't make a difference.
georgekale
Sounds like a corrupt program. Do you have SDD or acquire one to rerun camera and the park module program,. See if that helps?
georgekale
How old is the battery? These things don't like weak batteries. That's a thought?
Scott lamb
England
I’m having the same problem the button in cabin flashes 3 times and sometimes the camera will connect for a second then camera system fault flashes up
