Brake Noise
shanerrs
toronto
Hello All,
In January I had my rear brakes replaces -- Pad and rotors. Since then I have had ongoing issues with noise from the brakes - the indy shop I went to has replaced now the parking brakes, now replaced Rotors under warranty as they said the inner drum was warped - thus shifting and creating a noise when applying brakes
Now... after the 5th time to the same location (usually they are great)
I am getting a low volume constant noise - can't hear it at times, but depends on surroundings. Sometime after my drive to work, it is gone.
1-think it may be the parking brake not adjusted correctly - but it does go away and I would assume this would not be intermittent
2- parking brake not releasing enough? (thus after driving for a bit it releases)
Thoughts?
The parking brake cable issue?
