Blower fan wont spin
callsteward
maine
Good Morning.
My blower motor stopped turning.
Pulled it and it spins on 12v.
Replaced the resistor and fan still does not spin. Only 1.9 to 2.6 v at the fan harness.
HVAC panel lights. Only gives 21 and 22 errors.
What else is there to look at other than I was sold a bad resistor.
thanks for your experience.
ed
What year/model Discovery? Could be a bad switch, could be corrosion at the fuse block.
I would check corrosion at the fuse block, that is where the fan wire comes from and normally causes this issue. I have made more than one bypass wire for this issue. (fused of course)
callsteward
maine
Found it..
That isn't pretty at all. Glad you found it.
